CCW PID Block issues
jakeparsons03
Jun 2017
Indiana
78
So I have a PID block on CCW set up to control a motor. I have my variables input and the absolute error is changing but the CV is always 0. There aren't any errors and the block is active so I am not sure what the issue is. Does anyone have any experience using this block? Usually the built in help is very useful but not this time.
I've not used the PID block in CCW before, but using the PID instruction in a Logix processor, I've had that problem before when I've forgotten to set up the PID scaling. I also learned a couple of weeks ago that if you make any changes to the scaling parameters, you have to un-check and re-check the "PID Initialised" box to make them take effect (presumably they would also update on first scan etc, but that was the quickest way to make it work).
Again, haven't so much as even seen a PID block in CCW, but the scaling parameters is where I'd start looking.
Hey guys, I have no real experience with PLCs or PID control, but I was given a project that involves both and don't know anyone who can help me...
8,804
Long time listener, first time caller. I have a Micro850 PLC controlling the temperature in seven fermentation vessels at a local brewery. Each...
2,608
Hi there, I have a small heating system with a micro 830 PLC to assist with the learning process of automation and PLC's etc. The system is a...
8,311
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
64
