CCW Reading Analog In
Blshelt
Sep 2013
Tulsa, OK
Anyone have any experience with reading Analog in's using the 2080 if4 module? I believe it was set up correctly but it seems to only run once. What can be done to constantly monitor the analog in's using the CCW software? I used ST.
Hi Group. We recently added a 20 COM E Module to our powerflex 700 and assigned IP parameters to it. It can pinged and verify the connectivity...
2,534
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
63
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
237
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
171
