CCW V9 UID UIE instructions
JEANST
Jun 2015
PARIS
68
i'm working actually with CCW v9 on micro 850 plc's
i use a interruption STI0 to implement a IPIDCONTROLLER function
when i build the project
i have warnings about the variables both used by the cyclic program and the interruption.
"multithreads access to global variable should be inside UID / UIE functions" or something like this
i write variables only in the cyclic program, in the interruption, i only read.
so i don't think it would cause problem.
So i would like to implement these UID/UIE instructions in LAD and ST language but the warnings still appears..
If someone have an idea it would be glad
Thanks in advance for any help
Hello, no sorry it works but always the same warnings.. It would be interesting to have a support from Rockwell about this but i have not the Tech connect...
my ccw softwer stops working when i add and try to open a ladder program.
65
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
38
478
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
126
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
285
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
203
