CCW visibility tag question
lbric
Jul 2013
Bell Gardens CA
27
Hello,
i would like to make a "go to" screen button that is only visible once a user with sufficient rights has logged in. is there any way to do this using the user system tags and the buttons visibility option?
thanks
Ricardo
this is what i do. its a bit long winded but i believe its the only way to do it with the PV800s.
http://www.plctalk.net/qanda/showthread.php?t=99088&highlight=PV800
cliff notes version is you need to assign a tag in the PLC to the CurrentUser tag under the global connections in the PV800. Then use that tag in the PLC to compare to other string tags that you have in the PLC already setup. If the string compare is true, set a bit in the controller and then use that bit under the button visibility youre trying to control. for the price i like the PV800s and the Micro800 series stuff, but there is surely alot more work to be done on the programmers end for simple features that you may be used to with other AB products like the PVP series.
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
102
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
77
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
256
How to retain Values in CCW software? I am using CCW software and I can not find the Retain function in this software. Not even local or global...
182
