CCW with AB 753 drive
James Mcquade
Oct 2007
Nashville, Tennessee area
3,684
Hi all,
Saturday i ran into a strange issue, might have been something i did wrong.
We had an ab 753 drive that kept giving error 463 - dc bus overvoltage fault.
i went online with ccw version 12 and changed the parameter from 325 to 375
so we could run over the weekend. IS there a parameter save button i missed?
the reason i asked, we could not do anything with the drive after that, no auto or manual control. i tried to upload the parameters, download the parameters on the pc with no luck. i even went to the identical machine next to it and saved the parameters on the its hmi and and copy to this machine with no luck, it gave a download fault. i saved the parameters on its hmi and then downloaded them, and the system started working.
is there some trick to downloading the drive parameters?
i have uploaded lots of parameters with this version, and only had to download 1 time in the last 2 years.
ALSO, it there a training video(s) somewhere?
any information would be much appreciated.
thank you in advance,
james
I'm in the process of using CCW to download to a few PowerFlex 753 drives. All the previous drives loaded fine . The previous versions are version...
1,206
Good Morning , I just had to change out a PowerFlex 753 Drive . I'm able to ping the drive , but I cannot develop communication withh CCW...
1,873
Hey out there, I am trying to build an alarm que in CCW. I have got the FFL and FFU working, however the string that goes with the alarm can't be...
104
Hello. Has anyone ran into an issue with HSC on 2080-LC20. It run a cut off press and every so often after resetting to 0 it does not count...
77
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
256
