Change bit status AD P-2000
sparkie
Nov 2014
KS
1,148
I have a P-2000 and I'm trying to test out some sequencer logic. I was wondering how to change the state of a bit in a boolean array of values, but I can't seem to find out how.
You will have to do that in the Data View. Just create a Data View with the tags you want to force/toggle and then click on the Edit change it to a 1 and write the changes to the PLC.
If you look at the videos that are on the AD website they use this procedure a a lot during the demos.
Thanks Bullzi. I appreciate it, I'll check their videos. One more quick question: how do you get the task number for your task. I have them named, but am not sure where the number is. I'm trying to hunt down a couple scan errors.
Hello All. I am new to automation so please excuse my explanation. I am working on a request where I need to reset 2 alarm bits (AlarmError1_Alarm...
1,473
studio 5000 and compact i have an int that is a 1 second increment for something when a change in the int happens regardless of up or down i...
1,974
Hi All, I need some help on an application in which I am required to set up 30 second transition intervals between two displays. I've tried...
1,799
This forum is full of problems that people are having and possible solutions by the guru's. But the guru's never really get a chance to 'brag' or...
53
15,606
Compactlogix L33ER Studio5000 V26.01 PVP 7 standard FactoryTalk View ME V8.0 Pretty simple what I am trying to accomplish but I cant seem to make...
5,702
