Change DB type...
Jirrr
Jan 2009
Czech
167
Hello,
It is possible to change DB type in old Step7 or Tia Portal?
In Step7 I was advised to change type in Symbol table but it is not working...thanks a lot
I found this advise on SPS forum....the problem was that if there is a DB generated by CPU and I download it offline I can easily create UDT structure/if one knows How it should look/with symbols and right types and change simply type of this CPU DB in Symbol table....
but I presume that was not right?
Yes You are right....but to be precise it is generated by S7-317 in sinumerik,
and we need to detect error messages and NC states which are provided by this DBs,and it is a little difficult/CPU generated long Array of Bytes in DBs/...
but siemens provides UDT with right structures and symbols for this DBs,so my problem is how to connect this UDT with CPU-DBs??
Create your own offline DB using the UDT and then copy the contents of the CPU generated DB to your DB for error message and state reporting.
Good Morning , Just wondering . I understand that millivolts change when temperature rises . Does resistance change also ? Thanks in...
2,526
Anybody know if there is a registry entry that can be changed/added for Logix/Studio 5000 that will change the default data type for an analog...
6,354
Hi Friends, A quick one please. Can online changing of Thermocouple Type K to J (configuration change in 1769 IT6/A module) fault compactLogix...
3,781
Hello All, I am modifying an existing PLC program and want to change the controller type (from 1769-L30ER to 1769-L32E). I am currently using...
2,572
Hi guys, I wonder if there is an easy way to fill all my alarm timer preset values within user define data type ARRAY all at ones. This user data...
3,714
