Changing a parameter on GE fanuc controller
darwil93
Nov 2019
Florence
So we have this machine called a "quickwater" that we use to heat our low pressure water system. On the HMI screen there is a place where you can change the pump mode to either Auto or Manual. Every time power is cycled on the machine, it defaults to auto. The issue with this is that we only want to run it in manual. I want to change it so that it defaults to Manual when you cycle power. How do I do it?
A GE Fanuc VersaMax micro controller runs the system.
I don't have any experience with GE controllers. Any way you could steer me in the right direction as to how to do that?
Do I need any special cabling?
What software does that controller normally run?
The programming software is called Proficy Machine edition. Communication with that model PLC is serial, not Ethernet, so you will need a serial port on the computer that runs Proficy. That could be a USB/serial converter or a real serial port on an older computer. You can use the 15-pin RS485 port that the HMI is connected to or you can use the RJ45 (serial RS232, not Ethernet) port behind the door to the left of the HMI cable.
Your local distributor can provide the software and the proper cable. Most GEXPRO offices are authorized to sell the product line.
Another alternative would be to try to find a nearby integrator with GE experience who can come in and do the job for you. Based on your description of what you want to do, I doubt if it would take more than a few hours for someone with GE experience. Assuming you're in Florence Kentucky your proximity to GE Aircraft Engines in Evendale Ohio and GE Appliance Park in Louisville means there should be more than a few people familiar with GE PLCs nearby. GE's corporate policy was to specify OEMs of equipment for their factories use GE PLCs.
I am in my freshmen year of college and just started interning at an industrial manufacturing company that uses Powerflex 755 drives for many of...
2,406
Hello All I am new to the forum and also to the world of PLCs. I would like to have your expert advice, If I can change the floating point value...
5,776
I'd like to be able to change the parameter file so that I can change the tags used when i start ME. Or is there a way to pass parameters or...
2,676
hi all i'm using Pm554-E-TH plc using codesys i can compile the programme without any errors but when im running the programme this error msg is...
1,303
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
235
