Changing Battery of Fuji Electric PLC
Benyamin
Mar 2012
Dallas
67
Dear friends,
My Fuji Electric PLC CPU: NP1PS-74R need to be changed the battery.
The battery is located in front of CPU module. Should I turn the CPU power off in order to safely replace the battery? Can somebody send the link of its instruction manual please. Thank you in advance.
Regards,
Benyamin
You need to get the manual and read it BEFORE changing the
battery. Most PLC's say to keep power on - as in if the
battery is removed with no power the PLC will lose its program.
But the manual is the definitive answer.
I have Siemens PLC's which the battery is changed under power.
And an Allen Bradley where one must remove the PLC module
(power it down first) to change the battery. (It has a capacitor
to keep the program alive while changing the battery.)
Poet.
HI, im a student and never experience changing PLC battery. i have some questions in mind. 1. how will i know if the battery is low or it...
3,056
I have a Allen Bradley SLC 5/03 which needs a battery change. I've taken a backup copy of the program, but am worried about the 1747-SDN module...
2,564
Good Morning , Have a 1756-L61 CPU. Replaced the battery 2 times in the last 4 months. Have a red led on the CPU indicating a bad battery ...
3,063
Hi Would anyone have a procedure for replacing batteries on Siemens S7-300 and S7-400 PLC's. Thanks
36,042
PLC is C40H. I want to change battery but alm/err led is not yet blinking. I have not the programming console. If I follow the standard procedure...
1,500
