Changing IP address of CompactLogix L16ER-BB1B in Studio 5000
marko18
Nov 2021
USA
47
I'm trying to configure the IP address of my compactlogix l16er-bb1b in Studio 5000. I need to set it to a certain address as I'm planning on networking it with other devices via ethernet. I'm currently trying to set the IP by just plugging in a USB to the plc and changing the module properties, however this option is not available when I try.
The easiest method is to use your USB connection and RSLinx. You can browse to the controller and right-click on it and select Module Configuration. From there the Port Configuration tab will allow you to change the address.
OG
OG
I have only have licenses for Studio 5000 and Factorytalk View Studio. Do I still have access to RSLinx? If so, how do I navigate to it? I see similar looking menus to RSLinx when I open a new Studio 5000 project but I can't change the IP from there.
RSLinx Classic Lite is included with your Studio 5000 software. Take a look at the YouTube Snyd1 recommended. It should get you what you need.
OG
I need to change the IP Address on a CompactLogix 1769-L32E. It is already configured for one IP Address , but I would like to change. I thought I...
20,420
I’m an IT “fixit” guy working at a manufacturing plant that volunteered to help out with PLC’s. I know about .001% of what there is to know so...
3,772
I'm running ME 9.8 and I can get online with my Versamax processor via ethernet just fine. But for the life of me, I can't change the IP address...
1,794
I am using a Micro820 controller setup with the Modbus RTU in slave mode. Is there a way to change the slave address from within the application?
2,454
Does anybody know how to change the IP address of the series A flex IO comm module? This is the one that doesn't have the helpful 3 digit wheel...
2,429
