Changing parameters in the SCL instruction
May 2004
54
Hello,
Is it possible to change the parameter in the max scaled value line in the SCL instruction for RSLogix 500 automatically?
I have a 4-20ma input signal from a speed sensor that is scaled. What I'd like to do is if the speed reaches x rpm then I want to change the value in another SCL instruction that will then slow the motor back down. I would the PLC to automatically monitor the speed and have it adjust itself to keep the motor from going to fast and or stoping. Its more of a saftey, incase something goes wrong and the process doesn't need to completely stop but yet get back on track and correct itself.
Thanks John
if I understand what you're asking (and I think I do) then try using a memory location (example: N7:0) for the entry instead of a specific number ...
I actually thought of trying that. Instead of a max scaled value of 2500 I could try to insert N7:3 etc.. and the use a GEQ instruction to change the value of N7:3. I was going to try it, but I wanted to check to see if anyone has done such a thing. I don't like thoughs little Fatal Error messages on my screen.
Thanks I'll try it.
John
it's done quite often ... now if you want to prevent errors and things like that, you might want to look into "limiting" the value in the memory location to a range of "good" values just before the SCL executes ... this is usually done with two rungs ... one has an LES and an MOV ... the other has a GRT and an MOV ... ask if you need more help than that ...
I have a AB PowerFlex 755. I have it configured on an Ntron switch. I have a Machine LAN with a AB GuardLogix PLC, Point I/O, and a panelview+...
2,272
Hi All, I have difficulty in changing parameters on Allen Bradley VFD 1336 Plus, even I have successfully login in. I appreciate to your help.
2,129
One of my customers has an overwrapping machine with a PowerFlex 40 controlling the infeed conveyor motor. They want to decrease the decel setting...
5,613
Hi everybody. A few days ago, one of our system doesn't work (foam system) and its related person that working with this system claim someone...
4,106
Hi to all. We need to change a bad powerFlex 525 to a new one. How do you save the configuration to install in the new one? Thank you all for...
263
