Chart Creation using .csv file WINCC FLEXIBLE
RTA
Apr 2010
Bangalore
In Wincc Flexible 2008 datalog file which is of size 1.5MB. The data should be seen as a chart. I have used excel to create a chart but data is huge for excel so i am not able to navigate thru the chart i.e., data at different time. The logged data is of 4 hour duration, 15 Parameters logged and logged at an interval of 1 sec. Pl specify solution if possible within wincc flexbile or s/w which can get data quickly and display for report
Use the RDB format in stead of CSV.
From the online help:
File - RDB
Data is saved to a proprietary database for quick access.
Use the "File - RDB" if you require maximum read performance in Runtime.
Data logs of this format can only be read or displayed using WinCC flexible Runtime.
Convert the RDB file to CSV format using the "CopyLog" function to make the data available for applications outside WinCC flexible Runtime
Thank U Jesper
I. If i use native RDB how do i retrive it for displaying in a chart
II. Pl explain to me about sequential logging also
Hey All, I am attempting to create a bar graph(histograph) in FTView Studio. I would like to graph water consumption for each day of the week (7...
1,387
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
671
Anyone used the ActiveX Chart Control for their HMI Programs before? Short Demo Here : https://www.youtube.com/watch?v=jrS41-PhSGY Some Rockwell...
1,295
Hi guys! I'm new in SCADA and VBA programming. I'm trying to add 2 date pickers for start and end date to show trend history between them. I found...
2,181
I'm trying to get beyond "do-done" programming and utilize higher functions to make my routines smaller and easier to write. I've just started...
1,562
