cheap temperature sensor
awalinski
Sep 2002
38
Hi everyone!
I need an inexpensive temperature sensor which would be able to shut off the power to the relay running the pump. It's contact would be wired directly into the relay coil.
Ideally it would be mounted on a 1/4" plastic water tube.
Can you give me some advice where to look for it?
Thanks.
In my experience, Omega is a decent source of temperature equipment. Check out www.omega.com Their customer service is pretty good, so if you give them a call and describe your application, they can probably point you in the right direction.
I'm trying to predict when a peat moss pile is likely to undergo spontaneously combustion. Currently, it's a full-time job for someone to punch...
19
6,362
Looking to add a some temperature transmitters (loop powered)for some control cabinets .. tracking and alarming. Looking for a cheap xmitter...
4,311
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
250
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
134
95
