Disposable (cheap) wireless temperature probe
Th OP seems to have stopped responding, but I had a thought that might help someone else. A drone carrying a thermal imaging camera would be reasonably cheap and very flexible, they can fly predetermined routes and be very accurate in their GPS location. No need for cables or thousands of sensors.
Is the high temperature noticeable from the surface? I know you say you have to stick the probe in, but what about using thermal imaging?
Still a manual job, but someone could just walk around with the camera scanning for a high temp.
Although if this happens under a layer of ice...
Canada sounds dangerous! Exploding frozen moss is not a hazard I've encountered before
The piles are quite thick and tall - perhaps 30' at the base and 20 feet tall. Unfortunately, the peat is a very good insulator and it prevents the heat generated at the core from dissipating, or from being detected at the surface
Unfortunately, it's too late by the time the heat reaches the surface of the pile. The trick is to detect the rise in temperature before it reaches ignition temperature. if the temperature gets too high, it's too late. Opening the pile will just introduce oxygen and cause rapid ignition.
The peat is such a good insulator that the temperature change at the surface is negligible.
Anyone know of a cheap foundation fieldbus communicator? Something like the USB 8486 H1, but one that does not cost $3k? Thanks, Trevor EDIT: I...
123
84
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
790
I thought it would be fun to ask what everyone's favorite cheap-er HMI is and favorite features. My favorite features are how easy are 1)...
1,170
Does anyone know of a cheap USB to ControlNet or USB to DeviceNet adapter (I'm looking for both). I thought PLC Cable would have one but I did not...
2,315
