Chilled water control system
Charbel
Jan 2012
Beirut
307
Dear,
I am looking from control point of view for the chilled water control system, is it better to have heat exchanger in the plots? or directly going to the plots?
Chilled water system is serving an airport, from security point of view, client prefers to have the DCP in landside and all the plots served are mainly in the airside.
I see that it is better to have heat exchangers in the plots, in this way, we are able to isolate the DCP and heat exchanger control from DCP directly feeding the building which might cause problem in the temperature and flow.
Hopefully I can get some insight from you guys on this issue.
thank you,
charbel
what reason is there for the exchangers, if they are water/water you dont need them, the only reason can be waterleakage to avoid great quantities of water. negative is loss of efficiency.
There is a chilled water cooling loop in our process cooling a roller. It has been about impossible to tune. this is in a tertiary loop. From the...
3,236
Gentlemen, I have talked my way into designing a chilled water system, and I was curious if any of you could recommend a air to water heat...
1,976
Hello, Does anyone know if there is a sensor to detect levels of molybdenum in water with analog output capabilities? Thanks, Dave
1,381
95
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
676
