dwoodlock
Gentlemen,
I have talked my way into designing a chilled water system, and I was curious if any of you could recommend a air to water heat exchanger vendor?
Planning on using one with a 3ph fan, and I will adjust fan speed based on pre and post temps. Will also have a secondary water to water exchanger for the summer months when its hot.
I should add that I have no experience with this so if anybody has any tips or think my plan sounds retarded, I appreciate the input.
