chilled water sensor question
There is a chilled water cooling loop in our process cooling a roller. It has been about impossible to tune. this is in a tertiary loop. From the...
3,241
Dear, I am looking from control point of view for the chilled water control system, is it better to have heat exchanger in the plots? or directly...
1,626
Gentlemen, I have talked my way into designing a chilled water system, and I was curious if any of you could recommend a air to water heat...
1,976
105
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
705
