Choosing a PLC
vortmax
Nov 2011
MI
I'm investigating integrating a PLC into a scientific instrument that hangs off the wing of an aircraft. The PLC would control 6 heaters (using PID logic), control power to several components, report back various housekeeping data to the aircraft data system and act as a central point of contact to control the other components in the probe.
The biggest constraint I'm facing is that we want this unit to be fairly vibration and moisture resistant and function down in the -10 to -20 range (or lower). The board will be actively heated, but we don't want to ignore the possibility that the probe loses power in flight and chills down before regaining it.
I'm currently looking at the following units:
omega:
HE-XE and HE-XT series (http://www.omega.com/pptst/OCSXL_Series.html)
Triangle research:
FMD88-10 (http://www.tri-plc.com/fmd88-10.htm)
does anyone have experience with these units, or with another uni they would recommend for this type of application?
Look at automation direct they hooked one up to a race car search their site it might be worth a shot
In addressing both aspects, temperature and vibration...
Entertron has done extended temperature applications in the past, through subsitition of standard components for industrial temperature rated components. The majority of PLCs operate in a 0 - 50C range (approximately)
As a board level product, they have the ability to conformal coat the majority of the board for protection.
They have also been on some extremely intense products, including remote car crushers.
Feel free to email me (link in signature) if you have additional questions. I know I will, if you consider this product offering. There is also a link to the Entertron information on the ESI website.
Shalom and God Bless,
omega:
Triangle research:
The Omega units are actually re-badged Horner unitd.
www.heapg.coms
May get better pricing through Horner as well as support!
Good evening, I'm primarily a Siemens user, but I have an incoming project where I need to use Allen Bradley everything. So far I know that the...
2,672
I am going to daisy chain a couple Modbus devices off of a Click plc using rs 485. There will be three slave devices daisy chained off one another...
16
9,254
Good day all. I work for a small company that would like to start automating the production of our goods. I have been tasked with doing some...
49
13,620
Hello, Who can help with syntax of choosing DB by parameter number in PLC from HMI, for example? How to present some variable as parameter...
31
9,833
Hello, I am getting a new project and my customer want to use either AB or Siemen PLC, because he know that these two brands are most popular...
2,561
