Choosing best solution for industrial PC cabinet
Pandiani
Apr 2005
Tz
718
Hello to all,
soon we're going to be delivered a couple of industrial PCs SIMATIC PC IL 40 in 19" standard industrial format. Now we need to choose appropriate cabinet.
I want to place all computers in standard control cabinet with unauthorized access and dust/humidity prevention.
I have looked on the rittal web page and found a lot of solutions for PC and computer enclosures. Since this is standard industrial rack, I though not to order PC cabinet or anything like that, they have keyboard and similar stuff added and I don't need that.
I'm sure some of you have seen such solutions.
Keyboard, mouse and monitors will be on the control room desks, but computers will be locked in separate cabinets.
I need help to order right solution for me.
We expecting four 19" rack computers to fit in one cabinet (possible with fan on the top to keep dusz out and provide cooling).
Thank you very much
Just a quick comment: Fan and filter systems don't keep dust out. AC units keep dust out.
Stationmaster
To kinda clarify - at least in industry from what I have seen
I have learned this to keep dust out of cabinets
1. Shut the doors. AFTER you put all Panduit covers back on.
2. Ensure door seals effective
3. The muffin fans with foam or scotchbrite filters are ineffective.
4. Filter must be able to filter smallest particle in your operation. 97% filters seem to pretty well. Always wanted to try automotive filters never got around to it.
5. Blow PROPERLY filtered air into cabinet.
6. If needed use cooling (chill water, freon etc)
BUT make sure you design for condensation and a means to drain water.
Dan Bentler
The things you guy's are calling fans and filters we call them dirt pumps where I work because that is about all they are good for.
If you need to pump dirt in a cabinet then that is what you use.
Kid you need finer filters.
Yes I know
1. They clog too often. That is what they are for.
2. Management will say it costs too much
Dan Bentler
Hi friends, I want to know that which is best to start my carrier with. I have 2 option of system houses of the following company .:yeah: 1.Allen...
2,144
Good evening, I'm primarily a Siemens user, but I have an incoming project where I need to use Allen Bradley everything. So far I know that the...
2,648
Hello, I am trying to choose from 4 different tank levels (REAL) and choose the greatest number (highest) and set that to open that tanks valve...
1,882
I am going to daisy chain a couple Modbus devices off of a Click plc using rs 485. There will be three slave devices daisy chained off one another...
9,227
Good day all. I work for a small company that would like to start automating the production of our goods. I have been tasked with doing some...
49
13,558
