Cimplicity Error While exporting Points
premraj
Mar 2012
Mumbai
Hello Experts,
Can anybody tell me how to export tag from Cimplicity 8.0 V ? I have attached error with screen shot also. Kindly provide me solution on it.
Thanks & Regards,
Premsing
I am not sure what your error is, but here is what I do.
1. Open the project in Workbench.
2. Click the Tools menu, highlight Command Prompt, and click.
3. Type your command. For example: clie export myfile.csv. This will export every point in the project.
4. The file is located in the project folder. For example: C:\Program Files\Proficy\Proficy CIMPLICITY\projects\MyProject\myfile.csv.
For further help on the import/export, consult the help file. Search for clie. There are qualifiers you can add to the command to limit the amount of points.
I think if you do not open the command prompt from the project, you will have problems. You must be in the folder of the project. By opening from Workbench, you are automatically located in the proper folder.
hellow in our site we are using cimplicity cascade and after we creat a new point in the workbench, all the points in point branch are disappear...
860
We have PLC5-80e plc and cimplicity. There is look like loss of communication and The whole screens on HMI (Cimplicity) get black-out,we have to...
1,811
Hello All, I am using Cimplicity Machine Edition (TM) v4.50 Build 3173 and programming using State Logic, I have configured a CPX935. I have a...
3,254
Hi All, At the moment I have Cimplicity running on the server computer. I am trying to run the Viewer from my computer. However when trying to...
7,614
hii i have a problem with start project i get a errors and the start windows is not close automatic the error are LIOR_2...
5,374
