cimplicity 7 startup error's
dardary
Oct 2006
il
hii
i have a problem with start project
i get a errors
and the start windows is not close automatic
the error are
LIOR_2 E:\mtl_pal_mag\log\cor_recstat.clg
24/03/2008 10:24:21 Warning 3656 MAC_AM am_log_upd 0
No configuration for DLAP log file : ALARM_LOG
Error of type: COR_DL_ERR, Code: 10310
24/03/2008 10:24:21 Failure 3792 COM1 dcrp_user_open_p 20
Fatal - Local open of port failed - port is COM1
Error of type: Unknown, Code: 20016
24/03/2008 10:24:21 Failure 3792 COM1 dc_serial_window 2
Cannot open port COM1
Error of type: COR_DCRP_ERR, Code: 20016
24/03/2008 10:24:20 Failure 3748 MTCPSI_RP CPIL::_Additem 172
No connection to MSI_INTER.
Error of type: COR_MTCPSI_ERR, Code: 3
24/03/2008 10:24:20 Failure 2364 CfgCab StartSystem 2
**FATAL ERROR** --- CREATING PROCESS DA_RC
Error of type: COR_START_ERR, Code: 0
24/03/2008 10:24:20 Failure 2996 PM_MCP RDdef_act 2
Failed to create detached process DA_RC.
Error of type: COR_PM_ERR, Code: 15054
24/03/2008 10:24:20 Failure 2996 PM_MCP pm_credprc 0
Unable to locate program [BSM_ROOT:[exe]da_rc.exe]
Error of type: COR_PM_ERR, Code: 0
**FATAL ERROR** --- CREATING PROCESS MAC_DA
Failed to create detached process MAC_DA.
Unable to locate program [BSM_ROOT:[exe]da_rp.exe]
i did not find a sulotion for this error
eli dardari
Cimplicity 7.0 error
You are trying to run a project that was created in version 6.1, aren't you? If so, disable "Historical Data Analyzer" option in your project before opening it in 7.0.
193
Hello everyone! This is my first time posting, though I have been to this site a few times hunting for some random problem like we all do. I...
187
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
226
Hi All, I am trying to program some new Versamax micro PLCs through PAC using some programs saved in our archive however whenever i go to import...
129
Hi All, Im using Cimplicity 8.2. after the last restart Server Scada, the PTDL_RP process can not running. so Process can not be login to database...
165
