Cimplicity OPC Communication with Allen Bradley L73 PLC
Eugene_k510
Jan 2020
Malaysia
Hi good day Everyone,
I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic.
I have this issue of cimplicity not able to read the tags from my PLC when i starts to create more tags into the project.
my tags consist of these datatypes (BOOL, DINT, INT, REAL)
Is there any limit on the amount of tags for the communication through OPC Driver in cimplicity ? Cause my project seems to works fine when i reduce the amount of tags.
Hi Eugene,
Yes, there is points amount limit. Check you license and see how many points it offers. I ever had this issue and it did reach the limit, upgraded the license, and fixed.
Hi @JunQ thanks for your reply, im facing another issue here as shown at the attachement below. My project keeps getting this error COPCCallback::OnDataChange while cimplicity is browsing tags from my PLC and later on it will marked my PLC as disconnected.
I try to search on the manual for this error but can't get anything. Do you have any idea of what this error means ?
This is an OPC callback failure. I don't have this error before. Check the OPC configuration both on server and Cimplicity. For OPC communication, points update criteria - unsolicited or unsolicited on change- is recommended.
I'm currently trying to stand up a lab environment to test modifications for a client's existing setup. They are running Cimplicity 8.2 and an...
1,781
Has anyone setup an Intouch app as an OPC UA Server in the SMC (System Management Console)? Could use a little assistance... The fun thing...
5,387
Dear all, It's my first time configuring the cimplicity taking values from a remote Kepware OPC server on a Windows Server 2012 station. I have...
4,818
I have scanning application in which user scan rate is about 2 barcode scans per second.My current application architecture is as follows.My PC...
6,976
I want to communicate Cimplicity HMI 6.1 service pack 4 with RS link Gateway which is installed on remote PC . In detail ,I have Local PC "A"...
22
17,647
