Surferb,
As you said i open the Hardware Firewall Port 50000 between two domain so that my client PC will communicate with Server PC through Metrikon OPC tunneler , but it is not working giving error as " Incorrect PC name or Not IN NETWORK " ( At client gateway configuration in tunneler. i made port setting as 50000 ) . Also when i tried to ping both PC on different domain i.e. one on (172.21.0.xx ) & other on (172.27.0.xx) , are not pinging .So tell me what goes wrong & which other ports should i open in Hardware firewall so that my both PC should get ping.
Also i have one question that i installed tunneler on client as well as Server PC in same domain . Both pc were communicating only when i made port setting 21379 ( By default ) in client side gateway configuration Tunneler. Is there any limitation for tunnler for port numbers for unlicensed copy ?
