IOlink - Modbus Gateway
ds7891
Sep 2016
Las Vegas
77
Hello,
I've never dealt with IOlink and I am presented with a IOlink flow meter which I need to add to a modbux network (TCP or RTU).
Hitting up the Google machine, I'm having trouble finding a sigle channel/small Gateway allowing me to convert to Modbus. Everything seams to be a Multi channel block (Machine Mountable M12 connectors).
This flow meter is wired back to a control panel, the same place the PLC is. Would love to find something I can land the IO wires on one side, din mount it, and wire out the RTU or TCP for the PLC.
Any ideas?
You aren't likely to find a single-channel IOLink master. The cost-effective price points for building a protocol gateway with a network adapter are really at 4 and 8 channels.
Com-Trol is one of the founding members of IOLink and several other vendors sell their stuff under brand-naming. They do have DIN-rail IP20 versions of their gateways.
I have an Omron NX PLC NX1p2 which Supports EtherCAT . also I have Balluff BNI00HA Ecat Block(IOlink Master). I have setup communications and...
167
I hope somebody might be able to help me who has done some IO-Link messaging using an S7-1500 (TIA Portal 17) and the CMx8 IOLink module for the...
1,794
Has anyone here on the Forum used the new Banner DXMR90R-4K IOLink Master device with an S7-1500 or similar ProfiNet controller ? Banner has been...
908
Hi all, Apologies in advance for the awful title. I don't really know how to succinctly describe my issue. The platform is AB L320ERS2 v32...
2,427
Hi folks, I am having a hell of a time getting an E+H PMP23 scaled correctly in a CompactLogix PLC. I have tried all sorts of data manipulation...
19
7,050
