Cimplicity export Alarm Classes?
BigEndian
Mar 2014
Ireland
17
Is it possible in Cimplicity Version 8.20 to export the alarm classes to a csv file similar to the Clie database export??
I am also trying to figure out how to export alarms, having a problem with my existing alarms configuration properties are completely different from the properties of adding a new alarm. If anyone has some directions on how to export alarms that would be great.
There is a default alarm_log.csv export that logs alarms in chronological order as received. You may have to look at how your alarms are configured if they show up there or not. It exports every 24 hours to the default location, or an alternate if you have changed the default.
Thanks, I got it figured out for now, i had forgotten the alarms are basically the same as points. exported the point/tag database using clie export file.csv from command prompt and got what i needed.
Good morning, I have a Emerson/GE PLC with Cimplicity SCADA. I need to export data of a specific point/object to a CSV file and load the CSV file...
290
Is it possible to import and export device configurations from cimplicity and how? Also, does anyone have a nicely put together list of...
2,188
We have copied the project folder from one machine to another but it will not run and gives errors. So we need to at least export the tag database...
12,349
185
Hello everyone! This is my first time posting, though I have been to this site a few times hunting for some random problem like we all do. I...
185
