Cimplicity invalid update criteria for a DDE non diagnostic point
bradal
May 2006
edmonton
156
I keep getting a "cimplicity invalid update criteria for a DDE non diagnostic point" when I create or change a tag. This is an existing installation and I am adding some programming.
The existing project is up and running on the computer and cimplicity accepts tags that are updated on change. When I add changes here in our office to the project, it comes up with that error unless I choose "unsolicited on change". I have both cimplicity versions at the same SP level.
What might cause this??
I found this on another forum -
The DDE Client interface creates a Hot Link to the DDE Server. Non-diagnostic device points should be configured with an update criteria of Unsolicited or Unsolicited OnChange or the points will be found to be invalid.
I found the same article, and that is why I changed the upddate to unsolicited on change, and it accepted it.
What I don't get is that the existing system has all of its tags set to on change, not unsolicited, and I can modify those tags and apply them ( just to make sure it will accept "on change") and it has no problem.
It's weird.
I can't find what "Non-diagnostic device points" are or where they're configured. It seems to imply that your other tags may not be such tags. If you're gutsy you might try removing one and re-adding it. BTW, for others, the post is here.
hellow in our site we are using cimplicity cascade and after we creat a new point in the workbench, all the points in point branch are disappear...
877
Hello, I create little aplication just for testing connection between PLC and Cimplicity project running on PC. My setup is: 1. I created...
8,722
Hello, I am working with cimplicity workbench, I have made changes to the current project from this machine I am using in the past. However when...
56
I am currently working on a project involving Cimplicity 10, which consists of a setup with two redundant servers and five operator workstations...
43
The project on the operator workstation keeps disconnecting, even though I have an installation server and operating station set up through...
62
