Cimplicity ME Compare tool
unsaint33
Sep 2019
MInnesota
118
I want to compare two GE 90-30 projects. But it looks like my ME program does not have a compare tool. I found GECompareEngine.ocx file in my laptop. I have no idea how to use an ocx file. Can you tell me how I can use it to perhaps install the project compare function to my ME program?
GE Compare was a separately licensed piece of software. I think it has been discontinued.
You may have to use the brute force method to compare the two programs. Open two instances of PME and go through rung by rung.
One thing you can try without resorting to the GECompare tool (which I've never used either). Save each project under the same name in different locations on your computer. Open one of them and download it to the PLC. Then open the other one and go online with the PLC. You can then run a report that flags the differences between the open project and what's in the PLC.
174
Hello everyone! This is my first time posting, though I have been to this site a few times hunting for some random problem like we all do. I...
179
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
225
Hi All, I am trying to program some new Versamax micro PLCs through PAC using some programs saved in our archive however whenever i go to import...
127
Hi All, Im using Cimplicity 8.2. after the last restart Server Scada, the PTDL_RP process can not running. so Process can not be login to database...
164
