CIP Class/Instance/Attribute values for CompactLogix system settings?
Zazoo
Jul 2012
Maine
Does anyone know where I can find a table of the CIP Class/Instance/Attribute values for the CompactLogix system settings?
Specifically, when you add a GSV/SSV instruction to ladder logic in RSLogix5000 there is a Class/Instance/Attribute field on this instruction that allows you to set the particular attribute you want to get/set (e.g. 'Program'->'THIS'->'Name')
These values are selected with a drop-down of enumerated constants. However, I'd like to access these system settings externally from another device - to do this I need the actual CIP Class/Instance/Attribute number. Is this info published anywhere?
Thanks,
Mike
You are correct that the GSV and SSV instructions are used to access some of the same objects that the CIP Generic MSG instruction can.
There's no comprehensive published description of these objects; ControlLogix is a closed architecture and RA keeps a lot of this sort of thing close to the vest both for competitive reasons and so they don't have to maintain external interfaces for every object.
There are multiple special-interest documents in the RA Knowledgebase about particular CIP objects. The best index for these is Knowledgebase Article ID #24538.
I am trying to get some data from a Avery weightronix model 1070 scale to my compact logix using ethernet/ip. In my code I will use a msg...
27,405
Hi all. anybody has a reference to Rockwell vendor specific CIP class and service codes ?
3,068
Hello all. I am in the process of writing some code in Python to chat with a Logix controller. Part of the process has been to watch the...
3,275
Hi, The class codes in the specification only goes from 01h-f6h. For ones that are not within this range how would you find out what they mean?
2,634
Hi, First time poster, long time reader. I've got a mass flow controller device for controlling the flow of gas. It has a flowmeter and an...
277
