CIP - Ethernet/IP - Communication
manojvivek
Jul 2002
Hi All,
While communicating with ControlLogix PLC using CIP (Ethernet/IP) protocol, I am stuck up with handling different structured data types (at least pre-defined structures). I have a question in this context. Can we make the ControlLogix PLC respond in Formal Encoding format for structure data types instead of using Abbreviated Encoding Format? I mean, how to switch the controllogix PLC from FormalEncoding to AbbreviatedEncoding?. Thanks in advance for any help in this matter.
regards,
Manoj
Re:CIP-Ethernet/IP
Are you using MSG instructions with CIP Data table Read/Write OR Using your own code with RSLinx SDK for communication ? If using MSG Instructions , don't worry about data structures , it will take care of it . Please explain more of your requirment so that I may be able to help you.
Yes, we are using CIP services to communicate with ControlLogix through 1756ENET. It is our own code without using RSLinx. Hope you can provide necessary help for switching the PLC to communicate in FormalEncodingFormat.
Ok, you guys/girls, you are my last hope as I already tried their tech support who are probably correct on this matter but someone here might be...
3,122
Hello all, I have been attempting on and off for over a week to read the temperature out of a Watlow PM-6 to a Micrologix 1400 over ethernet. I...
9,250
Presently have a scale equipment that has an "EtherNet/IP" module in it. Use that to have in on ethernet along with a A-B Control Logix and have...
3,539
Hi, I've been writing a C program on OpenVMS AXP, to communicate with SoftLogix/1789-SIM module using CIP over Ethernet/IP. In...
13,201
I am trying to develop the C++ application with RSLinx CIP API. This application will send the CIP message to CompactLogix via EtherNet/IP with...
8,528
