Circuit protection and SCR Fuses
NetNathan
Nov 2011
Corona, CA
2,199
I have a 200A load and that is how I wired it.
The SCR Fuses that came with the 240A rated SCR are rated 350A.
The SCR fuses are 1 cycle fast fuses.
It is still okay to use the 250A CB protection (load x 1.25) with 350A SCR fuses, because the SCR fuses are rated for short circuit protection (spikes) only?
I can't speak to California, but that setup is perfectly legal under the Canadian electrical code.
I second James's comment, you need to consult someone who is familiar with your NEC requirements.
Following this thread. This is a good question. In my line of work, I was trained to put two different types of fuses on our SCR circuits. One will be a time-delayed, normally-sized fuse for simple overload situations and the other is a very fast blow, SCR-rated fuse to protect the SCR in transient or short circuit situations. It made sense to me, but was never sure if that was right.
Hi group! Repeatedly found answers to some questions in the PLC's programming world, now I decided to ask the question directly) Now I am...
22
4,244
Good evening everyone! This is my first post here, after extensive searching on the net I couldn't find an answer to my question so I thought I...
3,483
I generally design around using current limiting fuses in all the power circuits in the control panels I design. However, a recent customer...
22
9,905
we get frequent damage of the coils of our circuit breakers. our power supply is not really clean, sometimes running on generators. how can we...
1,959
We have a customer that requires Siemens, and wants fuses on all individual PLC outputs with indicator lights. Does the "short-circuit after M"...
2,286
