Citect 7.2 and Mitsubishi FX
ivo.maenen
Nov 2003
663
I have a small demo-project between Citect and the FX-cpu. There is serial-communication possible, this is tested! Changing the status of an input can be made visible on the Citect-screen.
But when I want to change a merker via a tag inside Citect, there is no change inside the plc-program. This merker M1 is only used to make an output high. By the way, there are no compilation-error's on this tag (=> M1).
My question is: can I do this; set a merker via a tag and see this action inside the plc-program?
Thank you for quick reply.
communication issue solved but in Express Wizard which driver,manufacturer or model I select for FX2n because in the list mitsubishi is not their...
I selected:
mitsubishi > melsec-fx-series-general > serial (point to point)
adress = 1
After I had finished the setup I needed to go to:
communications > IO-devices
and changed the protocol to:
MelsecF
Regards,
Ivo Maenen
Hi everyone, i try to connect my mitsubishi melsec fx plc with vijeo citect scada. The scada version is 7.30 and pc is windows xp. On the...
3,365
Hi, I need help in establishing communication between MelsecA3A PLC with Citect 7.2 SCADA, through communication link module AJ71UC24. The above...
3,589
I am using Mitsubishi MX4 (Citect SCADA) I am starting a new project shortly and wondered if you could help I am trying to create individual...
2,102
Hi Can someone tell me how I best can get to A1SH on Citect. The A1SH is connected to each an E700 terminal from Beijers. At first I thought...
3,223
