Citect CiCode 2018
jimtech67
Jun 2002
New Jersey
505
Does anyone have a Citect 2018 CiCode Reference Guide in pdf Format???
I know all the functions are in the help but.....
I like to print them out.
Yeah I'm old school &(old) but I find i easier.
I have the older ones 7.10 & 7.20
The Cicode reference guide was last included in version 7.50, Unfortunately it is no longer produced in pdf format. It is a 1,400 page document, that's a lot of paper to find your way around.
You can't just print what you want from the web help?
Yes I can.
I like the PDF format.
I printed the sections I used...
I have been developing Citect for years but with gaps
of easily 4 to 8 months between changes.
The bookmarked pages and hand written notes in the margins helped remember why I did certain things the way I did them.
Like I said Old School..
Thanks for the help
Yes I can.
Thanks for the help
I have been doing citect for 20 years, im an electrician, so cicode does not come esily for me. I just add lots of comments and remarks in my code for that same reason you mentioned.
i have got a Cicode reference for SCADA 2015 (V7.5) in pdf.
as Andrew says its 1400 pages. if you want a copy email me
a dot hoon at insulation dot com dot au
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
291
Hi guys, its my first time progamming cicode and I need to do popups alarms, there are several digital alarms and in their rising edge transition...
509
Is there a way to run a Cicode function in the Cicode Editor? I have a function that works but I would like to run it without having a button on...
2,992
in the past i have only been doing small mods to existing cicode and coping sections to reuse and modify to suit. Now i have been tasked to write...
2,788
Hi guys, I want to get data from Microsoft access database using vijeo citect cicode editor.. however, I don't understand what the coding in...
2,607
