Citect SCADA 2016 Tag Addressing
KorhanGencer
Oct 2022
Istanbul
Greetings,
How should I refer the variables that come from Unity Pro as tags in Citect SCADA 2016?
For instance, I want to import some tags whose addresses are in a shape like %I0.2.0. I saw somewhere that %I and %IW can be represented as %M when MODBUS protocol as MODNET30 is being used as communication protocol. Additionally, I presume %M10001 would refer to %I0.0.0.
But how should I refer some variable addresses like %I0.2.X or %Q0.5.X?
Finally, I couldn't find any helpful topics in "Help" section found in Citect SCADA 2016. Any such luck for finding a helpful documentation where I can read the syntaxes of various industrial automation communication protocols for different software?
Thank you in advance,
Korhan
Usually ...
In the Modbus Data Model, Inputs (%I...?)are separate from Holding Registers (typically memory e.g. %M...). To read Inputs, use Modbus Function Code 4 (0x04) Read Input Registers; to read Holding Registers, use Modbus Function Code 3 (0x03) Read Holding Registers.
Usually.
Of course, how Unity Pro and Citect SCADA implement the Modbus Data Model could be a whole 'nother thing. See this link.
[Edit: I found this. I think that suggests you need to map (copy? move?) %I values to %M and/or %MW locations and then Modbus(30?) can access those mapped values.]
[Edit II: this link.]
Usually ...
Usually.
Thank you so much for the information and documentation links. I'll be looking up to them and find a way to solve my problem.
Greetings, How can I create some structure tags that are similar to the ones seen in SIMATIC WinCC Tag Management section? Or does Citect SCADA...
1,176
just wondering if anyone has worked previously on Citect SCADA 2015 (V7.5) before they upgraded Citect SCADA 2016 (V8.0). i have to upgrade my...
8,452
Hi all, Does anybody know what the replacement for the DspAnMove command is? i could really do with being able to move an object referencing x y...
2,170
Hello. Recently, while working in Citect Scada 2016, two issues have popped up that I haven't been able to resolve, mainly, 1. Strings entered...
3,172
Hi All, Please advice me the issued that following slove the problem. Thanks. Bryan Image Link is below...
2,092
