Citect SCADA 7.2 Indirect Tag Reference
RayDell
Sep 2023
Texas
Hey,
I'm trying to do the following, I have some experience with Citect but can't seem to figure this out.
I/O Tag:
BoxPos1_ProdNum (Data Type: Integer) [Assume a value of 99 for this example)
Disk PLC Tag:
ProdNum99_Name (Data Type: String) [Assume value of ABC for this example)
Assume a slow-moving conveyor with Boxes travelling on it with different products inside. This is visualized on citect scada.
I have a Genie object which shows the product details in the box in a certain position on this conveyor.
In this Genie object I want to show the Product Number of the product in the box (BoxPos%Position%_ProdNum) and the Product Name.
When I place the Genie on the page, it asks me for the %Position% value, where I enter 1. This allows the Genie to resolve the Product Number Tag for Position 1 to BoxPos1_ProdNum. This then correctly shows a value of 99 on the object at runtime.
Now I want to use the BoxPos1_ProdNum value of 99 to create a reference to the relevant Product Name Tag ProdNum99_Name on the same object.
Any ideas on how this can be done? Hopefully I have explained it well above.
Thanks,
Ray
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
291
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
362
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
269
Hi All, I aim to use Aveva Plant SCADA 2020 to read and write data from/to Omron CJ2M CPU35 PLC using OMFINS protocol. However I have Bad Data...
728
