Citect SCADA and M241 PLC Modbus TCP Communication
kadbar
Mar 2017
Ankara
Hi everyone,
I'm an engineering fourth grade student and I am to new these topics.
I need to communicate between Citect SCADA 2016 and M241 plc with modbus tcp protocol. I configured the citect side by following the related documents. On the PLC side, I use the Somachine software and I configured the PLC for modbus tcp slave using explanatory documents.
I know that communication is provided by holding and input registers. However, I could not find any documents about how the steps of reading and responding to a request by the Citect should be performed by the PLC. All the documents I have found from the internet and sample projects in somachine show examples for PLCs working in master mode all the time.
Please help me to get this communication.🤞🏻 Thank you in advance for your help.
50
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
294
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
366
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
276
Hi All, I aim to use Aveva Plant SCADA 2020 to read and write data from/to Omron CJ2M CPU35 PLC using OMFINS protocol. However I have Bad Data...
732
