Citect SCADA Collector Issues
Tanquen
Jul 2014
CA
163
We have a customer running Citect SCADA 2015 (v7.50.1910). They are using the Citect SCADA Connector (v2.2) to write Citect historical values to the Wonderware Historian (v17.0.18000). Everything seems to work but the Citect SCADA Connector is sending data in blocks every 10-13 minutes. So for a time when you request that data from the Wonderware Historian it can be up to 10 minutes old and then it will backfill 10 minutes worth of values. So in the end, no data is missing or with the incorrect date time stamp but is unavailable for up to ten minutes.
We had them set all intervals to 1 minute and restarted the connector and it service but it still took about 10 minutes for the values to update after the connector was restarted and every ten to fifteen minutes thereafter.
There also looks to be an issue with adding the Citect Variable tags. I tried to add a Citect Variable tag and even though I set the Historize option to true I’ve not seen the tag in the Wonderware Historian. There is a warning in the SMC from the vjcHist.CitectVariableReader stating No variable tags found.
57147 WIN-8EH4FPGGF1N 10/18/2019 2:25:42 PM 941 0 1520 4672 SE.SCADA.Connector Warning vjcHist.CitectVariableReader
30
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
291
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
362
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
271
Hi All, I aim to use Aveva Plant SCADA 2020 to read and write data from/to Omron CJ2M CPU35 PLC using OMFINS protocol. However I have Bad Data...
730
