Citect scada hide tags
ALAN001
Apr 2010
UK
30
I want to hide some tags in a report when I print out
Is there a function I could use when my ELSE command is run to hide the tags instead of printing 0.00
The 0.00 is a Real Data type
FUNCTION CASH_SALE()
IF CASH_SALE_ON_CMD=TRUE
THEN GOODS_VALUE = LOAD_MIX_SIZE_PV * RECIPE_COST_PER_CUBE
VAT_TICKET = GOODS_VALUE * (VAT_VALUE/
100)
LOAD_VALUE = VAT_TICKET + GOODS_VALUE
ELSE
GOODS_VALUE =0.00
VAT_TICKET =0.00
LOAD_VALUE =0.00
END
END
Regards
Alan
You could create a memory based STRING tag. Then based on your IF the tag would contain nothing or it would contain the finished string which would be made up of static text "The goods value = " and have the REAL tag added to teh string after being converted to STRING by the function RealToStr(). It would look something like this
"The goods value = " + RealToStr(yourtag)
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
42
68
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
328
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
402
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
287
