Citect SCADA trending problem
ry_fern
Jan 2008
Caloocan City
44
Hi guys,
I have a Modicon Momentum PLC communicating with a Citect SCADA.
The problem is, the trend in citect is not match with the calculation in Momentum PLC. I had verified this after I go online with the Momentum and Citect.
I used a sub_real block of Momentum. The output of the block which is also accessed by citect is fine and accurate, however, the two inputs( IN1 and IN2)which are also accessed by citect are not. I also adjusted the trend sampling of the citect, sadly, it has an error.
Does anyone had this same problem before? Is there any adjustment that I need to do?
Thank you.
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
28
67
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
326
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
392
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
285
