Citect Scada
rakeshndas
Dec 2004
Trivandrum
Hello,
I have received an evaluation copy of Citect scada and have installed the same. Can any one give me an idea how to configure a Facon FBs PLC in the same so that I can monitor and control the PLC through COM port ?
I haven't seen the Facon PLC listed in the I/O device list.
Regards
rakeshndas said:
Hello,
Regards
Does the Facon support MODBUS communications? That may end up being your best option.
I have checked at the Citect driver web site and Facon is only listed as using a Modbus driver.
hello Bob and thank you for the comment. I just think now that I cannot use the same as the PLC I use with 3 ports, all the 3 ports are engaged. One for ModBus to AC drive, one for high speed link to other PLCs and serial port for MMI.
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
50
71
I am trying to display a variable within a cicode function onto a graphics page. This function queries a SQL database. I can get the value onto a...
328
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
404
I am new to Citect SCADA and I am building the graphics for a page that will contain the control of a plant by a Kingfisher RTU. The project I...
287
