CJ2M-33: access CF card using ethernet
Raventan
Aug 2016
Penang
Hi I am new to Omron PLC.
I am using CJ2M-CPU33 PLC with a CF card. Communication is via ethernet with IP address 192.168.250.2 (PLC).
When I open CX-Programmer, I can easily access the memory card content from there (see attached). But what I want is to access its content or the folder itself by file path directory (something like C:\Program Files\Dell), directly from PC.
I was thinking of something like \\192.168.250.2\Omron PLC\Memory Card\ but it did not work.
Please note that I do not want to use any third party program like IPSwitch or Filezilla. Any help will be greatly appreciated! Cheers guys.
Regards,
Raven
Here are the steps to perform using Windows XP or 7 FTP instruction:
- The PLC of the line is properly connected to the company network and office computers have access to the PLC. Verify this by opening up the ‘Command Prompt’ and type ’ping 192.168.250.2’ If replies are received, the computer is connected to the PLC
- Add the PLC information to the ‘HOSTS’ file located in ‘C:\Windows\System32\drivers\etc’ using Notepad. Add the following line: ‘192.168.250.2 Omron_PLC’. Full administrator rights are required. This step is only required once per computer.
- Windows Firewall Inbound rules may need to be modified to allow connections for ‘File Transfer Program’. This step is only required once per computer.
- To transfer a file, open the Command Prompt window again.
- Type FTP Omron_PLC
- Type Omron_PLC
- Type PASSWORD This is the actual password and the text will not show
- Type LS
- Type CD memcard
- Type LS
- Optionally, type CD to go to a sub directory as displayed by the previous command
- Type LS A listing of all data files will be shown
- Type GET xxxx.xxx where xxxx.xxx is the filename to be transferred
- Repeat the last step for other files as required
- To delete files during a FTP session, type DEL xxxx.xxx
- Type QUIT to close the FTP session
Note that the plc name has changed slightly by adding the underscore. Also the assumption is made that the password is 'PASSWORD'
Your password is probably different
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
174
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
64
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
110
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
117
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
229
