PWM Output on PLC Omron CJ2M CPU 31
rakhafrds30
Feb 2024
Yogyakarta
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the PWM output can't running. I dont know how to activated the PWM Output of this PLC setting's. Can anyone help me to activating the PWM Output on PLC Omron CJ2M CPU 31. I have tried to settings on Pulse Output and it cant change anythings.
To achieve High Speed Outputs (PWM) on the CJ2 platform, you'll need a CJ1W-CT021 module. High Speed function is performed in hardware.
If this is a new project, may I suggest you use a CP1L PLC as the High Speed Inputs and Outputs are built in. It is also much more cost effective unless the CJ2 is currently being used for other control.
If this is a new project, may I suggest you use a CP1L PLC as the High Speed Inputs and Outputs are built in. It is also much more cost effective unless the CJ2 is currently being used for other controli have
I have CJ1W ID211 and OD211 module on my PLC. Can this module outputing pwm on the output of PLC ???
ON Response Time 0.1 ms max.
OFF Response Time 0.8 ms max.
Those are the specs on the OD211. In addition, this card will not respond to Omron's High Speed instructions designed for stepper motors.
I just have PLC CJ2M with OD211, can i using pulse/PWM output on this PLC and how to settings this output ???
No software setting is going to make the OD211 any faster than the specs I posted. No, you can not achieve High Speed function with the hardware you have.
Hi guys, i have never had to do a PWM Output or input before i have a Device that to dimm the lamp output from the ballast, the ballast has a 24V...
1,049
Hi all, this is my first post and appreciate your advise in advance. I have a job to migrate a system form Mitsubishi FX5U to AB...
841
There are plenty of examples on the internet of how to make an LED fade on and off in a sort of pulsating or breathing pattern, but these all use...
17
5,841
Hi All I'm very new to the whole PLC world, and I was thinking of an 'easy' project to test a PID control loop. I'll share my thoughts on the...
4,930
Hello all, I have a PWM output 100mA, 50 Ohm from a CMOS driver. I want to connect it to a pulse input of a input/output card of a PLC. The...
4,212
