Click PLC Field Experience
Bullzi
Jun 2012
Colorado
1,530
Hi everyone,
I have started work on a couple of jobs that I think a Click PLC would be perfect for. The problem is I have zero experience with them in the field. I have one on my test bench and I have played with it some but never installed one for a customer.
What is your experience with the Click? Any issues or failures?
The panels will be installed outside in areas that can get very cold (-30F) which I know is below the specs of the Click. I am thinking about installing a small heater in the panel.
Just give my your thoughts.
We have a few out in the field and haven't had any failures yet. One of them is the telemetry master for a handful of water wells and has been running fine for 3 years but is in a maintenance building with controlled temp.
We installed a few more in outdoor locations in NEMA 4 boxes this summer and they handled the heat fine. We don't get that cold around here, a few degrees below zero is rare. I like the Click, and would keep using it when there is a cost concern, but we prefer to use A/B PLC hardware and software.
We do have some pesky radio modems that don't like the cold and I have used some small heaters from A/D to alleviate issues with them:
https://www.automationdirect.com/ad...nclosure_Thermal_Management/Heaters/016020-03
I used a temp switch so they don't waste power when the temp is above 40F.
https://www.automationdirect.com/ad...nagement/Thermostats_-a-_Hygrostats/011409-00
That little heater gets really warm and all I cared about heating was the aluminum bodied radio, so I mounted it to the same base plate the radio and mounted the temp switch right above it.
I have several in the field. No issues, either.
I would also consider the new Productivity 1000, also from AutomationDirect. Same price range, but more features.
But then he'll need to download and install a 2 GB software (CCW) that is not the best I've seen...
Just like any other piece of software there is a learning curve!
If he/she has never dealt with click software they will have a learning curve.
Thanks everyone for the info,
I did think about the Micro 820 PLC. I haven't used a Micro 800 since right after they were released and CCW was a nightmare. I have CCW just kind of gun shy to use it but I have heard that it has gotten better since V1.
Bullzi Buddy, I have installed 6 Now in the field without issues yet. probably at 2 years on the oldest one approx.
Just installed another, then they asked for PID Control. There isnt any built in but with some help from Bernie Carlton, i have PID Control now.
I Cant complain at all
Thanks Dan!! I know it gets cold up in your neck of the woods :)
Bullzi
You wouldn't have that problem with the new Productivity 1000.
They have made it a LOT better since back then... we stopped using them for a long time but then started up again about a year ago, that said I dont think you can go wrong with either, I have a few hundred of each out in the field and never had issues with either, but I dont know of any in a cold environment.
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,089
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
223
Hi guys, i have never had to do a PWM Output or input before i have a Device that to dimm the lamp output from the ballast, the ballast has a 24V...
1,059
I am trying to set a bit to command the Zebra ZT230 to print a label and receive a confirmation bit from the unit via an Automation Direct Click...
673
Hi All, I have a click plc the I need to bit strip and 16Bit int. This is to get the alarms from these bits in the int. Do anyone know how to bit...
511
