Click PLC "Flash Memory Error"
ClickUser
Nov 2013
PA
I have a Click PLC that is hung up at a remote location. It is connected to the internet with a serial to Ethernet bridge. I attempted to upgrade the software and the com link failed during the download. When I reconnected the PLC had a "FLASH MEMORY ERROR", the SC23 bit is set. I was able to download the new program and the PLC will not go into RUN mode as the error bit is still set.
The troubleshooting guide says to Power cycle the CLICK PLC. If the same error occurs again, download the project again and/or try the ‘Reset to Factory Default’ command. If the same error still occurs, replace the CPU module.
Getting someone out to cycle the power is not easy, possible but not easy. I can't 'reset to factory defaults' as the front panel switch on the PLC is in RUN mode.
Is there a way to clear this error bit using the Click Programming Software? Any other way to recover from this error?
Any help is much appreciated.
Complete noob here, using a Click C0-02DD1-D to run a test stand. Requirement is to turn on motor run for X seconds, turn off and dwell for X...
1,096
merry christmas and happy new year i have a click c0-00dr-d and allen bradley 2711c-t3m. can the panelview talk to the click plc via modbus...
228
Hi guys, i have never had to do a PWM Output or input before i have a Device that to dimm the lamp output from the ballast, the ballast has a 24V...
1,062
I am trying to set a bit to command the Zebra ZT230 to print a label and receive a confirmation bit from the unit via an Automation Direct Click...
675
Hi All, I have a click plc the I need to bit strip and 16Bit int. This is to get the alarms from these bits in the int. Do anyone know how to bit...
512
