Clock pulse for Allenbradley
techie_imtiaz
Sep 2010
Hyderabad
i want to know the instruction for Clock pulse(On/Off for few seconds automatically) used in Allen Bradley, just as BLINK in Codesys and SM0.5 & SM0.4 in Siemens.
As OkiePC pointed out, it depends on which AB PLC you are talking about. They usually have a free running clock that you can use bits from. Have a look at the S or Status File information.
Stu.....
In the SLC500 and Micrologix line there is the free running clock mentioned previously located in word S:4. Each bit in word S:4 toggles at 2^n time base intervals where n is the bit number.
For a PLC/5 you can set up a free running timer with either a 1 second time base or a .01 second timebase. If that timer were T4:0 for example, bit T4:0.ACC/0 toggles at the time base, T4:0.ACC/1 toggles at 2 times the time base, T4:0.ACC/2 toggles at 4 times the time base, T4:0.ACC/3 toggles at 8 times the time base, etc. Make the preset of the free running timer 32767 and unconditionally unlatch bit 14 with an OTU T4:0.ACC/14, that way the timer will never time out and it will never need to be reset.
For ControlLogix there are several options. You can set up a free running timer. But a better way for periodic functions is to create a dedicated program in a periodic task to perform the function without a timer.
There's a thread from about a week ago which discusses this on the Logix and uLogix platform. You could probably search my recent posts.
i want to create a timer of such to monitor 20,400 secs i know omron timers/counters only count to 9999. i know i need to create a 1 sec timer...
1,383
hi all i want a pulse clock generator in step_7:shock: so i can change the frequency & the on & off time thanks
4,636
how do I create a 1/10thsec clock pulse, if any one could tell me that would be great. Im using Syswin
2,375
Hi, I am searching for integrated clock pulse flags (i.e 1 second or 2 second pulse flags)for a Siemens 928B CPU, and not having any luck...
3,919
I am Using omron cx-programmer. In this programme the 1-sec clock pulse bit timmer is avalable in programme itself.I want to add new 5sec clock...
6,146
