CLX 5000 Scan time??
Alaric said:
If you are accustomed to RSlogix5 or RSLoigx500, placing the two output instructions in series might look a bit funny to you, but this is perfectly legitimate in RSLogix5000.
Is putting two outputs instructions in series the same as putting two output instructions in parallel? (As far as the processor is concerned.) Would it have the same effect?
Yeah I think it is the same. The logic scan is a 1 at both points of the parallel branch. SO I am goin giwth yes
Thats right. The logical solution of the rung is exactly the same.
However, placing the outputs in series is three fewer instructions because the rung ends with
OTL F1AxisReq.Reset OTL F1AxisReq.Home
As opposed to
BST OTL F1AxisReq.Reset NXB OTL F1AxisReq.Home BND
The branch start BST, next branch NXB, and branch end BND instrucitons don't have a significant impact on scan, so I'm not saying that serial placement is superior to parallel placement, rather I am just boring ya'll with the details of what the differece is.
Go with what you feel comfortable with and what is most readable.
Not to add to the confusion, but look closely at the options in CLGX for a task execution. The execution of all tasks and communications overhead is very much asychronous and not at all like the SLC-500 and PLC-5s. These older PLCs scanned inputs, executed logic and then wrote outputs. CLGX is timeslicing various tasks etc... Often times logic that seemed logical in the older PLCs makes no sense in CLGX due to this.
Hi All Can anyone let me know where I can get a list of the bits like First scan bit S:fc ,I think and so on in Clx 5000. Talk soon Donnchadh K
4,589
Hi All, While building the offline project for CLX 5580 with 1756 Rack I/O, I noticed that there is a field for "Series" and "Version" for some...
715
Hi All, I am relatively new to CLX/PLC but not new to the automation field, to give you some perspective. In Studio 5000 Logix designer, when you...
933
Dear all, may be people here wants to share experiance about interconnection between two controllers AB 1756-L73, as per this attachment pic, im...
2,881
I ned to send data from a ML 100 to a CLX 5000. Can this be done with a msg instruction or is there a better way? thanks
2,646
