CM1243-5 Comunication to Field IO
pmcmahill
Oct 2007
Ohio
I am new to Siemens and am working on a project. I need to communicate between a S7-1214 CPU with a CM-1243-5 (Profibus Master) to field I/O (Beckhoff I/O). I was told by someone that i need to use DPRD-DAT command in program. However, in the TIA V13 software there is a network setup where i have setup my Beckhoff I/O. Which is correct and work the best?
o_O
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
86
Hello all. I have a future project planned with a leibinger jet3up inkjet printer that I will have to send the print details to the printer via...
1,256
Good evening partners, ist my first question on forum, i hope receive any answer. I need make a cable DH485 for communicate an Panel View 550...
2,930
Hello guys, I have compact Guardlogix L30ERMS with IP address set to 192.168.1.11 a Panelview compact 600 with IP 192.168.1.12 and a 1734 AENT...
2,608
Hello I am tasked with placing the R&B PLC X20CP1381 with Lenze 8400 Highline 8400 inverters using the Canopen protocol. I am looking for an...
1,333
