1734 AENT error: comunication timeout
Ashrits
Jun 2019
New Delhi
Hello guys,
I have compact Guardlogix L30ERMS with IP address set to 192.168.1.11
a Panelview compact 600 with IP 192.168.1.12 and a 1734 AENT series B with IP set to 192.168.1.13.
every device is discoverable in the RS Linx tree just not the 1734 AENT ethernet module.
I've 3 IO module connected to this 1734 AENT module with chassis size set to 4
I'm getting error 16#0204: Communication request error.
The IP at the thumbwheel of the 1734 AENT is also set to 013 which is 192.168.1.13
I tried connecting to the 1734 AENT module with the BOOTP-DHCP tool but it doesn't discover the module too
what exactly has gone wrong here?
Welcome to the PLCTalk forum community !
Can you PING the module, get a response from its built-in Web page, or see it in an RSLinx Classic browse ?
If you have the rotary switches set for .13, then the IP address is definitely 192.168.1.13, regardless of any other settings.
What is the status of the diagnostic LEDs on the 1734-AENT ? Have you verified there is no conflict by PINGing, unplugging, and PINGing again ?
Hi... i am using compact logix l23E plc with 1734-AENT modules, AENT modules are connected on the ethernet network, in one of the aent module...
2,666
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
761
Hi All, Have got a problem which i first thought to be a network problem but now starting to think we have got a broken 1734-AENT PointIO unit...
29
4,508
Hello. My facility has Point IO modules (on a separate cabinet) which is connected to a controllogix PLC via 1756-EN2T module. We lost...
1,424
Hello, There is a small test rig in our work which is sometimes salvaged for parts. The test rig is connected to a small robot used for training...
1,648
