CN2R/B self test failure upon powering up
mazen.nawar
Nov 2016
Egypt
Hello,
I had a serious issue yesterday that caused 5 CN2R/B modules to fail. We recycled power (accidentally) on our Redundant chassis V(19.052) & Remote I/O Racks of our control system.
We have 2 Redundant chassis & 6 Remote I/O Racks all connected by CN2R/B modules.
I turned off power on every single rack one by one and began to turn power up on every rack one by one also, I found that 5 control net modules were stuck on the TEST indication and OK led was solid red, I tried to recycle power once again and still nothing, This issue happened before for two CN2R/B modules and we replaced them and worked fine, but this time 5 controlnet modules went down, including one module that was replaced before.
Also one of the modules that went down , something strange happend, after about 1 hr of TEST indication we tried one last attempt to recycle power on this rack and controlnet passed its test and worked fine , we tried this on the other racks but nothing happened.
We checked all our grounding connections & our power supply feeding the Racks & they are fine, no problems found at all.
kindly tell me what should we do to avoid such issues.
Also, u should know that one 1756-RM/A module went down when recycling power on one of our primary chassis.
luckily we had some CN2 modules spare, I replaced them with CN2 /B temporarily until we replace them with CN2R later.
what happened how to avoid this again ?
we do regular power recycle on our control system once a year.
Hi Team, If I change the 1756-CN2R RPI value in online will it goes out from the Schedule. because we have experienced the same situation...
626
can anyone help me to programmatically get data from a 1756-CNB (R) and 1756-CN2 (R) modules using CIP message? info such as: max_connection...
2,034
I received this in a PM yesterday from a new member, TLEMCEN, who has not posted to the Public Forum yet. With respect to our new member, and...
2,594
Hi all, I have to replace a faulty module of 1756-CN2R Series B for IMCS System. The system has 2 redundant rack which I believe for software...
3,074
In allen bradley PLC, Whether it is possible to replace the CN2R module with CNBR module in a network having all others CN2R module?
2,068
