Code Sample: Crimson 3.0 String Pattern Matcher
marv_tech
Apr 2022
East Coast
25
New here so not sure if this is allowed, but this is something I developed for a work project to enable the usage of USB barcode scanners with some input validation. It works with Crimson 3.0 HMIs(and auto-migrates to Crimson 3.1).
This is a testbed I prettied up a bit, I have bug tested it to the extent I needed to but it is probably worth testing any patterns that are critical before using them.
Usage looks like this:
pattern.isMatch(input string,pattern string) which will return a boolean true if matched, false otherwise.
Pattern syntax is in the comments and also on the "guide" button on the test page.
To use in your project, just copy the "pattern" program folder to your project. That's it! If you end up using it, just shoot me a thanks if you can.
Some screenshots here: https://forums.mrplc.com/index.php?...-30-simple-string-validation-pattern-matcher/
Thank you for posting, I will have a look when thing quiet down. RedLion really should have somewhere on their site so that people can upload stuff. Maybe there could be somewhere here.
Hi All, I would like to ask you if possible to have some samples code for the realization of a software filter to be used in a PLC Micrologix...
2,104
Anyone use the ModbusSlaveTCP.L5X for CompactLogix? I have it installed and cannot seem to set the Modbus (Instrument) ID. I'm expecting to set...
1,990
Does any one have a sample code for creating recipe in RSLogix 5000. I need to be able to save 20 recipes that could have up to 20 ingredients...
2,396
Hello All, I have been trying to refer to the "Day of the Week" Sample code that came with my rslogix 5000 package, however I am receiving an...
17
14,158
Help I have limited plc coding experience & need to input 0-10 volt dc analog into cscape to show results on meter screen. I have NO idea where to...
2,781
