sample code cscape analog input
simpleman
Dec 2015
north dakota
Help I have limited plc coding experience & need to input 0-10 volt dc analog into cscape to show results on meter screen. I have NO idea where to start. A sample code diagram would be VERY helpful. Thank you.
It has been several years since I did any work with Horner products. Back when I did, they followed the GE style of addressing. If they still do, the data from the analog input module will show up in %AI memory. For a 0 - 10 volt range, the value in the %AI memory location will be between zero for zero volts and 32000 for 10 volts.
Unless you are using an analog module that allows for scaling the %AI data in the configuration of the module, in which case you will have to look at the configuration details.
Danw, Cscape is Horner's programming software.
I have attached 5 images, start with 01.
Happy New Year!
New here so not sure if this is allowed, but this is something I developed for a work project to enable the usage of USB barcode scanners with...
1,229
Hi All, I would like to ask you if possible to have some samples code for the realization of a software filter to be used in a PLC Micrologix...
2,086
Anyone use the ModbusSlaveTCP.L5X for CompactLogix? I have it installed and cannot seem to set the Modbus (Instrument) ID. I'm expecting to set...
1,973
Does any one have a sample code for creating recipe in RSLogix 5000. I need to be able to save 20 recipes that could have up to 20 ingredients...
2,370
Hello All, I have been trying to refer to the "Day of the Week" Sample code that came with my rslogix 5000 package, however I am receiving an...
17
14,115
